Wind deflectors Mk2 FL
I have the exact same ones as in your link, that's a great price too.
They're very easy to fit, and Team Heko are a well known brand and are of good quality too...I'd say go for it!
Hi thanks for the reply. In contact with the seller now.
I have team heko on my pre face lift mk2 and they look smart and easy to fit atb kev.
Cheers thanks for the reply
I have these heko deflectors fitted to my 2011 octy... Be warned, they cause wind noise around 70mph. Not major, but a noise which is defo noticeable.
Thanks for that, have a little wind noise already so I'll drive at 69mph
to avoid any more noise. Cheers
:giggle:
Heko here too. Recommend.
I have too much road noise to worry about wind noise. Differing road surfaces make a huge difference.
I think it makes more sense to call them rain deflectors rather than wind deflectors, as they allows you to leave the windows open a bit to get rid of (or prevent)condensation, especially as Skoda's seem to have weak climate control components.
ditto to Tilt
I had team heko on the Fabia. Fitted really well. Bought some for my fl vrs estate and the road noise was quite intrusive and for some reason the rear ones managed to let water in at the top of the Windows. Going to refit them again over the weekend but I think I might just end up leaving them off. Which is a shame as the car looks loads better with them on
Heko here too, very good fit and quality.
Car gone now :(
Edited by Defenderben
Quick question. How are they fitted?
No similar problems on my estate, fronts and rears fitted, using metal clips supplied.
They almost hold themselves in, especially the fronts, but you get metal spring clips supplied with them and you push the clips into the window seal recess at the top and then just push the rain (Lol) deflectors into the clips. Closing the windows should firmly sit the clips into the seals, and the deflectors into the clips.
I have only had to adjust my rears slightly once in a few years of fitting. Generally no issues, and do not really find wind noise that much more noticeable.
Pretty easy.
Edited by Tilt
