Heaters Not Blowing
Think my heater has died on me, its no longer blowing hot or cold air out of the vents. Is it a hard job to replace I know you can gain access to it from in the foot-well under the glove-box? Also was checking the fuses to see if it had blown while the engine was running, now I've got 2 warning lights on the dash engine and glow plugs lights, any way to clear these?
Edited by Darrenm72
Did it just stop working? If so I had the same few weeks back. It was the motor resistor Costs about 30 quid.also if you look on YouTube for how to fit resistor it shows you how.
Got it working again Simon the fan was a bit stiff and i spun it by hand, when I turned ignition back on again it work \0/ \0/
