Fabia MK II GearBox
To day i noticed a whining or a winding noise but it very low compared to the one on the video https://www.youtube.com/watch?v=mi2t_VT6YWg and generaly @ 1st and 2nd then desapear (when motor sound become louder i can't hear it). @ 3, 4 and 5 it's difficult to hear it. Is that  normal ?
PS : i have a manual gearbox and 10000 miles
https://www.quora.com/Is-it-normal-for-a-manual-transmission-car-to-make-a-whining-noise
http://www.transmissionrepaircostguide.com/10-common-transmission-problems/
Edited by didou25
What motor is it? The supercharger in a TSI motor will whine noticeably if you have a window down, especially if you are in sport mode.
I was assuming a Manual by the video of the manual truck.
So Diesel, Petrol, what model.
But i know nothing about manuals.
would it be the same car you spoke about in this thread? the HTP?
http://www.briskoda.net/forums/topic/382978-fabia-ii-12-htp-acceleration/#entry4480040
whats the whine like? dont tell me the gearbox is buggered too?
Yes it's the same, the noise can be heard only from the interior when the windows are closed and the radio off it's the same sound you get from the revers gear (hmmmmmmmmmmmmmmmmmm), i didn't gave any attention to this until few day ago when i was driving without radio. i'll record it. regarding the acceleration problem every thing is normal according to my dad and to every one who drove it.
Edited by didou25
2015 Fabia, 1.2 HTP, 70 Hp, Manual Transmission, 10000 miles
Today i gave it to a friend, he drived it in a parking and the noise can not be heard from the outside
Edited by didou25
I tested it again and i found :
Whining @ 1st from 1000 to 3000 rpm
Whining @ 2nd under 2100 rpm
Whining @ 3rd under 2100 rpm
Whining @ 4th under 2100 rpm
@ 5 th dificult to detect
The sound is similar to the one produced by the electric window motor and the one made by the reverse gear but lower then these 2.
Sombody told me that the motor is a bit quiet (good sound insolation) that's why i can hear the gear box.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1990484
Edited by didou25
its still under warranty isnt it?
Yes but my dealers mechanics are not very good they damaged some cars and i am 100% sure that they are going to tel me every thing is good since the gear change is very smooth.
Edited by didou25
But you are asking strangers that can not guess what the issue is.
Where are you, is there no other Dealerships near with good technicians, or ask an Independent Mechanic to try driving your car
and give an opinion.
and give an opinion
I'm just asking about the sound if they have it or not, do your car make similar noise (a humming @ low rpm in 1st and 2nd)
Edited by didou25
Maybe try another dealership then?
It doesnt have to be the one you purchased the car off, and Skoda dealership will do (:
But did you noticed something similar to what i did describe
My gearbox doesnt whine in any gear, at any speed
Even in reverse
Even in reverse
It does make that noise in reverse if you speed up that every car makes. Its just the way the gearbox works. That whine in reverse is perfectly normal.
Edited by fabiamk2SE
As said above, the whine in reverse is perfectly normal and happens in every car, it's because the gear for reverse has straight teeth and all the others have teeth that go diagonally on the cogs so they engage smoother.
However the other noises shouldn't happen.
I found this on youtube. Similar sound for the first 15 sec
Its really quite difficult to tell off a video even.
Is it defo the gearbox and not the 3 cylinder howl which is normal?
Ie. Does it do it in neutral?
Nothing in neutral,
can any one make a record of noises that can be heard inside the car
Of what, a normal fully working htp?
Yes, but from inside the car when moving @ 1st and 2nd from 1000 to 2500 rpm
