07 plate rear suspension
I have an 07 plate Vrs and my rear wheels seems to dip in at the top..( sorry not very technical) just wondering if anyone else as had this and if they know what I need to change.. Every other Octavia I park next to does not look to have this.. And every garage I take the car to does not seem to have a clue what it could be even skoda main dealer ..
Would have geussed at a rear alignment issue,you can make them move in all sorts of wierd directions if you mess with the camber etc
that was one of the many things i have tried .. had them all done and they said that its set how it should be.. thank you for the reply thou
Did you get a print out of before and after. The corrected settings should be in green writing and anything that is out should be in red.
it was around 6-7 months ago.. i did get a sheet showing me it had been slightly adjusted which did stop some rubbing when i had a full boot and car full.. i have been told not to worry about it as i get normal wear on the tyre's.. its just really bugging me and i'm thinking maybe a bush as gone but can not see anything.
I wouldnt trust the garage mate until you see a print out,took me 3 different garages until one finally cured my problem of heavy tyre wear
I thank thats whats confusing me.... im not getting any tyre wear uneven
