1.4 tsi not starting first time, seems to be 4th lucky
Hey all,
Her indoors has issues with her octavia 1.4 tsi not starting today. It will crank over nice and fast but refuses to fire at all.
I tried it this evening and on the 4th attempt it started like nothing was wrong?
She ran it by a friends today who's partner told her his scan mentioned a fault of (I hope this is right she remembers all I do that's wrong)
01314 engine control module 004 no signal/communication intermittent.
Does anyone have any ideas of where to start with this?
Found this if it helps any:
1314 - Engine Control Module: No Communications
Possible Causes
  • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
  • Fault(s) stored in Engine Control Module
  • Engine Control Module recently flashed or re-mapped
Possible Solutions
  • Check CAN-Databus Wiring/Connectors from/to Engine Control Module
  • Check Measuring Value Blocks (MVB)
    • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
  • 3 months later...
Thought I better update this incase anyone else suffers the same problem. There was corrosion in the fusebox and on the relay terminals! They charged her a fair bit of money to fix it, as wasn't a warranty fix. The car has been fine since however.
Corrosion in the fusebox/relay terminals? In this day and age? Are VAG rewinding us slowly to the 1950s?
