Scan results help
OBD2 - confirmed:
P0135 - O2 Sensor Heater Circuit Bank 1 Sensor 1
Engine:
P3255 - Oxygen Sensor B1 S1: Heating Circuit Regulation at Upper Limit, Upper Limit Exceeded
Engine:
P1093 - Bank 1, Fuel Measuring System 2, Malfunction
Engine:
P2195 - O2 Sensor Signal Bank 1 Sensor 1, Biased / Stuck Lean
Instrument cluster:
01299 - Diagnostic Interface for Data Bus (J533)
Heater & air conditioning:
01317 - Control Module in Instrument Cluster (J285)
Telephone:
01524 - Antenna for Telephone
Telephone:
01304 - Radio
Telephone:
Telephone:
00992 - Consumer disconnection actively
CAN network gateway:
01300 - Control Module for Navigation with CD-Rom (J401)
01304 - Radio
Obtained with Carista 3.0 beta-9 for Android.
Download app: https://play.google.com/store/apps/details?id=com.prizmos.carista
Facebook: https://www.facebook.com/caristaapp
Sent from my Samsung device
Sent from my Galaxy S5 using Tapatalk
I take it I need a new lambda sensor?
Did you clear codes first and then see which came back or is this the first scan?
This is the first scan
Clear it, get on to live data and compare data to desired engine figures, I.e. Fueling and intake. Look for O2 sensor output too
Haven't got tools to do that. Broke down at J1 at the start of the M6 by the M1. Put on a low loader and brought home.
Bugger, what was it doing when breaking down?
Seemed ok. Did notice I'd used more fuel than normal
Cut out instantly or stuttered to a stop?
Bonged on so pulled over. Engine off. Left 5 minutes. Started back up used for a mile. Then pulled over and rung the breakdown. Light didn't go off but drove ok
Edited by J306TD
Does Carista do live data?
No but just remembered I have torque paid version
Take a look at live data and post it up :) give us a shout if you need a car until Octy is sorted
Haha cheers. I've sorted a lift to work this week.
Might just get it changed. Job done then
Get a genuine part, so much less hassle :) good luck with it
Could someone please get me the part number of it
Got hold of a genuine one from Mike at Listers for a really good price
Part delivered today.
Been to make sure the car starts today. Ffing instrument cluster has died!!
What do I do?
Fixed it. Unscrewed cluster used hairdryer on it came back to life. Battery had also died which didn't help. Took car straight to garage for a run. Airbag light didn't go out though
Sometimes airbag won't without being reset, some times it's instant. Annoys me
Once started with a bit of help. Left it to idle for 10 minutes. Then took it straight to the garage but drove carefully. They are going to fit lambda sensor tomorrow. Clear the codes and check the battery
Lambda will only make it misfuel, my Fabia was driven for 2 months like it
I don't fancy a new cat. After its had too much to drink of petrol
That was knackered on mine and all ;)
