Strange Issue - ESP, Airbag, others
Hi Chaps,
I'm looking after my dads car, and i just started driving it again after being sat for a month, car started up fine, drove half mile to the petrol station, filled up diesel, started driving again, and within a quarter mile and just turn a corner, the car made a beeping noise, esp light came on, with power steering warning so i drove home just up the road, switch engine off, went inside the house had my dinner, came back to the car couple hour later. Started car up fine, no beeps, no warning lights, i thought brill, reversed out on the road and drove half way up the road, esp and airbag light on and every now again power steering warning came on with beep and stereo unit say no optical parking available (it does work when put in reverse), so i continued driving for about 3 miles hoping it will clear itself, parked up at a retail car park, switched engine off, waited about 10 mins, started up again, esp light, engine management light then airbag light, and power steering beep & warning every so often, continue driving and hoping it will clear, but it doesn't get better next the central locking unlocked then locked, and repeat a couple of times. So drove back home i sort it out tomorrow argh.
The car drives fines, just all the electronic warning issues, no limp mode whats so ever. It seems like the canbus system has gone faulty as it can't communicate properly.
Was thinking one thing i could try tomorrow is disconnect the negative lead of the battery for an hour then reconnect so the car reset itself, that's the only solution i have at the moment.
What do you guys think problem could be.? Any help and advice is appreciated. :)
Car is a 2010 Octavia DSG 2.0TDI 140
Cheers.
Done the battery disconnect for an hour method. Started car up, started fine, but engine management and airbag light on, test drove for 10 miles, no new issues. Got back home plugged in the code reader - error code U0155 google the code 'No Communication with Instrument Cluster'. So i erase the fault code, engine management light gone off, airbag light still on. Test drove the car again another 10 miles, during the drive, esp light came back on and then power steering light on & off with beep then the doors unlock and lock, what i have notice every time the power steering warnings comes on and beep, the doors unlock then lock again same time as the pas warning.
I have also notice the power steering warning and door unlock/lock when i turn left or bend to the left. Which makes sense now, as the issue only started when i turned left then all these issues came.
What can it be guys?
Update... the battery has been left on charge for 8 hours. Installed it back into the car, started up, the airbag & pas lit up, then after about 10 secs the pas light went off, only the airbag light remain on, took the car on a 20 mile run lasting 30 mins, no new errors. This was last night.
This afternoon i took the car out on a 8 mile trip, airbag light remained on and nothing else. on the return journey 5 miles in, the esp light come back on then the pas light intermittent, doors unlock and lock intermittent.
Do you think it needs a new battery?
Edited by raimon
Been reading on here even if the airbag fault has been fixed, the light would still be on and it would need clearing via VCD.
The drive to work this morning 20 miles had only airbag light on, then the last mile the esp light had to come on along with a beep..
So lets say is normal the airbag light is still on until cleared, why did the esp light come on for the last mile. Electrical/battery fault maybe?
The battery seems to be charging and running Ok. There is an indicator on the battery to show the status, i shall upload a pic later.
Any help or advice appreciated
Thanks.
When I had random problems with my maxidot and instrument cluster lights I ended up needing a new cluster.
Although I believe a low battery can also induce random issues with warning lights. If it's a 2010 on original battery I'd be tempted to replace it. At nearly 6 years old it's probably due.
Ray came round tonight and I scanned the car and this lot turned up:
Something very odd is happening, now the car freaks out everytime you turn left.
Tuesday,23,February,2016,19:11:03:25882
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: XXX   License Plate: XXX
Mileage: 74370km-46211mi   Repair Order:
Chassis Type: 1Z (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 52 55 56 62 72
VIN: XXX   Mileage: 74370km-46211miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFHC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 CT    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H22 7101
   Revision: 42H22---    Serial number:
   Coding: 001D0012042500080000
   Shop #: WSC 73430 031 00092
   ASAM Dataset: EV_ECM20TDI01103L906018CT 003004
   ROD: EV_ECM20TDI01103L906018CJ.rod
   VCID: 7EF9BC9BE1926FCE0C-802A
4 Faults Found:
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 3
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
4714 - Steering Column Control Module
          U0212 00 [032] - No Communications
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
4715 - No Communication with Instrument Cluster
          U0155 00 [032] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
4719 - No Communication with Diagnostic Gateway
          U0146 00 [032] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 054 J    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2602
   Revision: 05351112    Serial number: 00001010251332
   Coding: 0000020
   Shop #: WSC 73430 790 00088
   VCID: 1D3B9B17C4D4D4D675-8048
4 Faults Found:
18097 - Powertrain Data Bus
            P1689 - 000 - Implausible Message from Elect. Load Controller - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
18082 - Powertrain Data Bus
            P1674 - 000 - Implausible Message from Instrument Cluster - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 133B401C09290001C81202EC90190082310000
   VCID: 76E9A4BBC1A2278E54-8022
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 16
                    Reset counter: 86
                    Mileage: 73942 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 16:59:28
             Freeze Frame:
                    Count: 0
                    Count: 0
                    Count: 4608
                    Count: 8208
                    Count: 50944
                    Count: 3616
                    Count: 9
                    Count: 0
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 16
                    Reset counter: 86
                    Mileage: 73942 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 16:59:51
             Freeze Frame:
                    Count: 16384
                    Count: 0
                    Count: 12800
                    Count: 8210
                    Count: 49409
                    Count: 7707
                    Count: 1783
                    Count: 3072
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
   Component: Climatronic   H16 0402
   Revision: 00005001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 76E9A4BBC9A2278E54-8022
No fault code found.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 48000ABAE85BB1C040080084110011A4437000AE726D85605C4540000040
   Shop #: WSC 25078 576 96662
   VCID: 38756A838B3691FE86-806C
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 09111  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 181110 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 4 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
7 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 75
                    Reset counter: 86
                    Mileage: 73940 km
                    Time Indication: 0
                    Date: 2016.01.21
                    Time: 13:47:53
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.05 V
                        OFF
                        OFF
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 45
                    Reset counter: 85
                    Mileage: 73942 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 19:34:20
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.20 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 14
                    Reset counter: 84
                    Mileage: 73943 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 19:36:24
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01314 - Engine Control Module
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 25
                    Reset counter: 84
                    Mileage: 73943 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 19:36:24
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01321 - Control Module for Airbags (J234)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 19
                    Reset counter: 84
                    Mileage: 73943 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 19:36:24
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01315 - Transmission Control Module
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 84
                    Mileage: 73955 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 19:59:28
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.25 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01309 - Power Steering Control Module (J500)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 84
                    Mileage: 73985 km
                    Time Indication: 0
                    Date: 2016.02.12
                    Time: 00:50:00
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32991031612205
   Coding: 10810E
   Shop #: WSC 13765 790 00088
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000.rod
   VCID: 336F5DAF9A5072A6B3-8066
4 Faults Found:
12666403 - Databus
          U1121 00 [008] - Missing Message
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 71
                    Reset counter: 85
                    Mileage: 73942 km
                    Date: 2016.02.11
                    Time: 16:59:51
12666400 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 62
                    Reset counter: 85
                    Mileage: 73942 km
                    Date: 2016.02.11
                    Time: 16:59:51
12666401 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 56
                    Reset counter: 85
                    Mileage: 73942 km
                    Date: 2016.02.11
                    Time: 16:59:51
12666402 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q8 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC22J9PJ
   Coding: 0020792
   VCID: 3D7B7B976414B4D655-8068
   Subsystem 1 - Serial number: 6332MSME57131878B
   Subsystem 2 - Serial number: 6342MSME5822625FH
   Subsystem 3 - Serial number: 6351HSME25013453X
   Subsystem 4 - Serial number: 6361HSME247F5468J
1 Fault Found:
            004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101117301773
   Coding: 1882140000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 943 M    HW: 1Z0 920 943 M
   Component: KOMBI         H20 0420
   Serial number: 00000000000000
   Coding: 410F00
   Shop #: WSC 73430 031 00088
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 438F0D6FCAF0C22623-8016
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 211110F2001805
   Coding: 352303
   VCID: 306552A3634649BECE-8064
3 Faults Found:
00469 - Infotainment Databus in Single Wire Operation
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00111011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 72783 km
                    Time Indication: 0
                    Date: 2015.09.23
                    Time: 09:10:06
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 77
                    Mileage: 73978 km
                    Time Indication: 0
                    Date: 2016.02.12
                    Time: 00:23:55
            001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 43
                    Mileage: 73940 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 11:40:24
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6AD180CB8D1AF36EC0-803E
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1102
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F6751DFBE785646D7-807A
1 Fault Found:
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2120
   Coding: 0005118
   VCID: 76E9A4BB01A2278E54-8022
2 Faults Found:
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   VCID: 316357A7A84C40B6C1-8064
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 131
                    Reset counter: 85
                    Mileage: 74364 km
                    Time Indication: 0
                    Date: 2016.02.18
                    Time: 02:14:05
             Freeze Frame:
                    Voltage: 14.13 V
                        DU
                    Temperature: 38.0\B0C
                    RPM: 1293 /min
                    Speed: 28.0 km/h
                    Speed: 28.0 km/h
                    Count: 0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0005118
   VCID: 48951A433BD6E17EF6-801C
2 Faults Found:
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1507610
   VCID: 346D5EB3575E759EAA-8060
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000023
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000023
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 G    HW: 1Z0 035 156 G
   Component: BOLERO        015 0029
   Revision: -----29S    Serial number: SKZ4Z3K1132902
   Coding: 0D0004000001
   VCID: 366964BB8122678E94-8062
6 Faults Found:
00625 - Vehicle Speed Signal
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 52
                    Reset counter: 86
                    Mileage: 73942 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 16:59:51
01327 - Control Module for Parking Aid (J446)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 61
                    Reset counter: 86
                    Mileage: 73942 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 16:59:51
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 59
                    Reset counter: 86
                    Mileage: 73942 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 16:59:51
00849 - S-contact at Ignition/Starter Switch (D)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 27
                    Reset counter: 84
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:34:14
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 9
                    Reset counter: 85
                    Mileage: 73943 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:36:37
01704 - Terminal 58 (Dimming)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 86
                    Mileage: 73953 km
                    Time Indication: 0
                    Date: 2016.02.11
                    Time: 19:57:10
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012568
   VCID: 326158ABAD4A7BAEB8-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336F5DAF525072A6B3-8066
End-------------------------(Elapsed Time: 02:44)--------------------------
Gateway Installation List:  7N0 907 530 C
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Readiness Status: 00000000 00001110 11101000 00101000
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Passed
Number of EOBD-related DTC(s): 0
VIN: XXX   Mileage: 74380km-46217miles
   Coding: 0000020
   Revision: 00H31001
   Revision: 00005001
   Coding: 0000000002
   Revision: 00103 AD
   Coding: 00D7B7
   Coding: 0730ED
   Coding: 10810E
   Coding: 0020792
   Coding: 1882140000
   Coding: 800000
   Coding: 410F00
   Coding: 352303
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 74380 km
                    Time Indication: 0
                    Date: 2016.02.23
                    Time: 02:30:39
   Coding: 000000
   Coding: 0005118
   Revision: 00H17000
   Coding: 0005118
   Coding: 1507610
   Coding: 00000023
   Coding: 00000023
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 02:35)--------------------------
                Address 01: Engine  (03L 906 018 CT)
19:38:45
  027   Battery voltage 12120 mV
The problem only happens when i turn left. Before it was just tc, airbag, pas coming on. After resetting the code, went for a drive, it seems fine.
About to leave simons, i had new errors appear on igntion, simon reset the codes again. No more new fault codes. On my way home, the errors came back including new ones. argghh its gone crazy, dashboard light on and off, rev drop and back on. abs error, bend lighting error.
Update. I took it to an auto-electrician he believes it's either canbus gateway or software issue. He believe it's more software issue side by the unusual things the car is doing, so I had it in at the stealers for diagnostic and software update. They started out after diagnostic scratching their head, then thought it was the fuse box, then checked the wirings, and finally canbus gateway.
The cost for the repair with diagnostic £430.
My question is, is it common for the canbus gateway to fail. And is the price quoted reasonable, as part is 200 something pound.
Thanks.
Given that there are very few (if any) threads on here about failed CAN Gateway in ANY Skoda model, I doubt that this is the direct cause of the problem.
IF the gateway has failed, what caused it?
I suspect that there is a wiring fault somewhere causing intermittent power supply to one (or more) controllers. Probably the CAN Gateway; but I'm no auto electrician so please don't ask me how to check this.
Have you read this? http://wiki.ross-tech.com/wiki/index.php/00532
You seem to have eliminated battery as a source of the problem, but it could be wiring (or connector / wire interface - I've know early Fabias to have issues in this respect).
Edited by KBPhoto
Thanks guys. I give the dealers a call to see if they have checked the wiring to the gateway.
Did you take it Gordon Lamb? They took 3 attempts to fix the wiring to the drivers seat airbag on my car.
Sent from my D5803 using Tapatalk
Sandicliffe, my dad would off took it to Gordon Lamb Edited by raimon
Did you get to the bottom of this as I'm having very similar issues.
Yep, the dealers fixed it, and they not charged for their trial and elimination. First they checked the wiring, all ok, then replaced can gateway, not that so removed, next ignition control, wasn't that so removed, reconnected wiring, this seem to have fixed it.
So the cause is lose wiring to the can which seems common on here.
