Techie's new runabout
Have you changed the door speakers too?
  • Replies 275
  • Views 52k
Toons are working4CB871C2-7660-43C3-B2FD-9DC85416B3D3_zps75818230-CA71-47EE-A18C-B3E3588259EF_zps
And so have the coil overs :)
coilovers! Pics or it hasn't happened :)
Edited by TrevorB33
Yeah, Alpine components up front.
Hasn't happened yet. They are waiting to be fitted :)
A few pics from today at the unit...
BA0048F0-6C51-422F-8C6E-841D22FAAD56_zps
7A089DE7-B4E5-4FF7-9C82-A647EE5CAA0E_zps
F4C3BDD6-9280-4643-9E1F-8FFE276DDBA5_zps
92446D3E-6F0E-4066-A879-CDD9D6436347_zps
0796CCC1-382E-41EB-B63B-4D02E2B806E8_zps
B37B6670-2141-4C75-AE06-233AEB800AFE_zps
0C6DEA3F-C09D-491E-AA83-DB054C9F9907_zps
9C9C9DA1-228F-4615-BBFC-A5FD0C852BCF_zps
E0F19F6A-2E4C-4FFE-B417-D657667FF72A_zps
B74A3146-BC6D-4972-98D5-10558498BCB9_zps
112965FB-0011-48A3-9384-40C38D9531D7_zps
Ready to continue with the front end overhaul :)
Edited by Tech1e
Did you sell the 1.8T?  :D
The engine yeah. Everyone's doing them these days though ;)
I like the colour, looks pretty clean under back too :)
Some more fun, frolics and frustration at the unit today.
First up taking the front struts off, driveshaft was seized solid in the right hand hub. Need to do a wheel bearing on this side. But a seized driveshaft doesn't pose an issue when you have the tool for the job.
7B149029-B99D-4610-899C-688D9021EB4D_zps
There are a few issues with this car, but most of them have been caused by work done previously by less than competent monkeys. The amount of stuff installed wrong or broken is shocking tbh. Taken twice as long fixing things and getting things how I like them.
Nice job on a CV boot there
3FBB26A4-683C-478F-B8D8-1A0AA1285A2D_zps
Now looking much better
19D3C15E-8EB4-473B-9886-DA2B31F97C18_zps
Console bushes were laughable, installed 180 degrees out and cracked when installed. Also old wishbone bolts reused previously and over tightened so one was a struggle to get out.
New bushes in though
E30CFF2A-E4F1-4393-8CAD-2C5168131494_zps
And cleaned up the bolt threads
64185158-79B9-4768-B0F7-1EE99795A73C_zps
Handy kit to have
1A88BFE5-F5C4-4414-ABCE-7105968B3264_zps
The exhaust flexi had bust and had been bodged very badly so picked up a new flexi and welded it in
1CCF3693-E9D7-4940-9CE7-63CB3CAAD4C1_zps
63ADEFDA-3D4F-4BC0-8655-0D33C742CD55_zps
Best job that could be done considering how it was. But will be gas tight now at least.
Ribbed belt is in a state
E8390775-C1A2-4C6F-9B62-55DE90705201_zps
927D3CF1-ED2C-4017-8822-74FBCC555E70_zps
So figured I'd have a look at the cambelt (both on my to do list anyhow)
02DCF64B-CBD9-4AFB-A0D9-D2AECBB74C48_zps
Lucky escape, guide roller has come apart and lost its outer casing (pretty common). Wasn't making any undue noises and ran fine though so it pays to check these things. New belt kit is ready to go on anyhow so no worries.
To be continued...
  • Sponsor
Like the driveshaft pusher tool. :)
Gonna do water pump too?
Yeah I'll pop a water pump on too.
Got a Continental timing belt kit from ECP, was either that or INA. Looks pretty decent, damn site better than what's on there anyhow.
Thats driveshaft tool is simple but good. Wish i had one. Might make one [emoji38]
Has come in handy so many times
ACC2850B-CE78-4FA9-97FE-84CD3188C0DD_zps
Top mounts arrived, Meyle items.
One of the threads had pulled out on the caliper sliders so helicoiled that. Still need to fit the new wheel bearing and build the subframe back up so it can go back on.
1634AC39-3E48-4F90-8824-C721F57C6B26_zps
Subframe now back on, left hand hub all built back up and the wheel bearing tool has just arrived. I can now swap that and build that side back up.
Cambelt in progress, rather lucky with the roller.
FFF1F90A-70D3-4546-9362-A6648A38D825_zps
Edited by Tech1e
Good work as useual [emoji38]
Question for ya. Fitting G60/vr6 clutch/flywheel setup onto my car, what would you suggest with the flywheel bolts? 45lb/ft and 90 degree? Thats all info i found.
Iirc that's for the flat shallow head bolts, yeah?
Yeah, theyre not the m12 splined like what came off.
That's right then. Be very careful with them, easy to slip off.
2404B911-B59F-497C-817B-3BCFB669E409_zps
Cambelt all done and wheel bearing sorted, now back down on all four wheels. Really needs a clean now bless it, it's minging.
bloody hell that alternator belt was cracked never seen a belt like that before
Front coilovers on then? :)
Yup
These should be a bit better to perch on.
5789AAF7-64F9-43D8-9077-14E6465526C9_zps
55D5E625-2390-499A-B307-9D1144BFA752_zps
Edited by Tech1e
So how to get a set of seats from an Ibiza Cupra in Coalvile back to base for the saloon?
Remove all the seats (bar the drivers of course) from the Scout, drive to the chaps place and fit them in to drive home.
7CED64A9-7378-41A4-8CF7-3B16AF28350C_zps
Simples
