Techie's new runabout
Couple more from a few hours tidying up and tinkering
162E38B4-3844-4ABA-B88D-F5B4B71E59D6_zps
024F96FC-1803-4C05-87FF-995665BCE0E5_zps
Would have fitted the clutch and flywheel too had I remembered to put it in the car.
  • Replies 275
  • Views 51.1k
9E3351D9-9FBF-4D1D-9BD7-6700F5396B24_zps
More essentials :)
Last couple of bits ready for tomorrow's session.
11DC3735-EBAF-4FBD-BE20-AE6DC07BEBE0_zps
So it all kicked off today.
Sump off and new oil pick up on.
FC199CD5-50ED-445E-9317-700C306A567C_zps
New G60 flywheel
9DC99C12-AF6C-403E-912C-0862676BBAD0_zps
New cambelt, damper and water pump
7064C585-88B1-40E6-802F-608322055C6B_zps
And well, in the hole
7B111BA3-8B08-43E9-AE0D-E04DA91ED45F_zps
D760DA16-4E15-420F-8789-FA69D3D7CB58_zps
13D38677-F257-4FDD-B8E6-78ABD61B47DD_zps
Not bad for a day's work.
  • Sponsor
Reckon I could've probably achieved that in a week. :D
As a side note my car is a 2003 with ABS and had a speed sensor in the gearbox (not a dummy).
Be interesting to see if my speedo works or if I can adapt my dash to use the ABS signal.
  • Sponsor
Guess there's no sensor on the box that's just gone in?
I could swap the sensor, it has a dummy one in it but the wiring for it is part on the engine harness on the 1.4.
  • Sponsor
Ah, that's good; so you can hardwire the sensor output up to the clocks if it can't be made to play nicely with just ABS speed input. :)
Moved along with this very quick!! Looks awesome! Good job ross
This almost makes me want to buy a saloon. Absolutely awesome this, those wheel trims seem to work so well for it too
Few more pics from this morning.
Ibiza loom and pipe work now in the engine bay.
20966E2A-443A-47A1-A34D-E608D6195C9C_zps
Donkey back in
8966F723-D9B6-4767-AFD7-4836B65C82FF_zps
Kinda get the idea now
D6DE7089-C667-4EAA-8B11-4F7541CE5811_zps
Edited by Tech1e
Looking good! I wish I was as capable as you are in the car department, I can't believe how quickly you seem to work.
It's taken me all day today near enough to delete the egr and remove the egr cooler on my BKD Octavia! Lol
Edited by AshVrs
Many years of practice.
Just caught up with this. All coming along nicely :thumbup:
Just the one photo from this morning.
DDA77E77-E12E-4973-A2B6-B1FD22EA2546_zps
Pretty much there tbh. Just waiting on the ECU. That and decided to pressure test the cooling system and the heater matrix pipes are leaking where they go into the car. This connection is a known ball ache. I fitted new pipes and seals too when the engine was out and double checked the seals hadn't pinched but looks like they have. Balls. The 1.4 connection is actually a lot better than the 1.8 so might look at adapting that. Not a great deal of room due to the turbo though.
Oh well, it will get sorted in the end.
Just the one photo from this morning. DDA77E77-E12E-4973-A2B6-B1FD22EA2546_zps
That's why I bypassed mine lol, such a stupid design, you can chop the original Fabia one down and add some 90degree silicone hose off it, but like you say it's very tight, close to the actuator
I have the 1.4 MPI metal connection that takes rubber hoses, then some universal 90deg bends. As you say though, very little room. I was worried that the actuator would rub on them but fingers crossed its been good for 14k or what ever I'm up to now :)
Exactly what I had in mind. Wish I hadn't forked out £45 for the genuine pipes now, cest la vie.
7990CCAC-9207-4553-8E22-3405FF6548A6_zps
Edited by Tech1e
E77AFBA9-484B-4AD7-B446-4D55A2608473_zps
6E6378D9-47AA-41BA-8161-1706FED32D2B_zps
Awesome :) what did you do with abs module Ross swap Ibiza item and reconfigure the pipes?
No, left my original on there with all of the original pipes.
Can you adapt the connectors then, as mine was completely different, from pre facelift Fabia, to facelift Ibiza
Mine was exactly the same. 03 chassis Fabia and 04 chassis Ibiza.
Damn that's lucky :) mine was 02 to 06
Edited by TrevorB33
