Techie's new runabout
That's the one! Subtle.. :-)
  • Replies 275
  • Views 52k
Wanna swap cars? Ill put my own 1.8t in this [emoji38]
Sold lol
Did they cover it in superglue and ramraid a Halfords? ;)
I reckon with a smoothed bootlid that would look boss.
I don't see a problem with that.......maybe put gull wing doors on it :)
Thought I'd have a look at why the drivers window wouldn't work on my way home after work. Took the door trim off, obvious signs of ****ery going on in there. Lock rod missing, missing screws and a well and truly toasted door speaker. Check out the wiring which seemed OK, fuses ok, power and earth to the motor. Had a feeling the motor was goosed. CDL also wasn't working from the switch, motor seemed prime suspect. Then I remembered ages ago I got a window motor off one of Bossfox's breakers for a customer that never showed up. Could I find it in the depths of my unit? Would it be the right one? Well yes I found it after a bit of a rummage, yes it was compatable and yes my windows and CDL now work. Yay!
Drivers side front carpet is a bit soggy but given the state of the carrier I'm not surprised so will pull out all the interior shortly. Prob sound deaden the doors and run some nice cabling for the stereo while I'm in there.
I think I just out Scouted the Scout
8E1B4794-6A88-4F42-8FF0-0BCF98FD1336_zps
83B2B4D1-4278-4E23-8B99-6A0E4C4AF052_zps
Liked that setup on your previous Fabia. Just needs to go abit lower now!
Monster truck :)
Turns out after a bit more poking about the rear carriers have been leaking (as normal) and it's a bit soggy so....
D080CF38-3643-40C1-8D82-3D367BFCAABC_zps
BFAEC5F9-00C4-473A-8BCF-E6BD805B429E_zps
D1DD72BB-C3F9-4ABB-B2BF-7849AA619ED4_zps
338E9731-B221-48B1-9C61-32ED2C704D09_zps
Carpets out and drip drying
0191CD57-F716-45D4-9263-BC02E3635910_zps
Certainly more spritely up the road minus the interior. Maybe a tad noisier too.
Edited by Tech1e
We've figured it out, from the ride height and the interior, so you might as well tell the truth.
You're going rallying aren't you? :)
Edited by StevesTruck
Dash out for a rear door carrier leak :p, might aswell fit a 1.8t interior loom while your there :)
Definitely going to the extreme... I like it!
Must have had a little moisture behind the airbag :D
Dash came out for another reason but kinda made sense anyhow. Not like a lot holds them in really, only took 45 mins or so to get the lot out.
There's something pleasing about how chunky it is for sure.
The question is do I order an original os tail light, or change the ns to a later one?
Well I guess the facelift is seen as an upgrade.
I guess it's all down to preference though really.
I'd definitely stick with what it should have, and put an earlier light back on it.
I'd change the NS if it means having an early front and late (looking) rear!
  • Sponsor
Cheeky request: If the dash is still out, could you take a bunch of photos of all the electrics on the right? The stuff that you can't usually see anything of; relay carrier/onboard supply control unit/ etc.?
Would be very useful as a reference when trying to describe how to get to various bits and pieces like those.
Id go for a facelift light.
Of course, no problems.
I think the rear lights should stay as they are, adds a bit of character
A few pics from after work today, more tomorrow. Decided as the interior is out its a good time to spec up the audio.
Fuse link goes on
00518EB7-931E-4218-9C98-D84BC3144C0B_zps
4AWG cable routed into car
AC72C19F-2862-4FD5-BC5E-E4EF5367F80C_zps
E4EBF8BC-C834-486B-B885-0538ED3AD978_zps
This ain't gonna leak
9E081768-7181-4BA4-997C-5108E53C0D64_zps
Cable routed down the side nice and tidy
487D576D-8A0D-49E3-A47B-71B6AD27032C_zps
And into the boot
124BB04B-7D36-48BC-97A5-1FF9E0A91CDD_zps
I have an idea where to mount the amp, see if it works.
More pics tomorrow.
