24mm white line rarb
so today consists of me fitting the rarb. now ive picked up a second hand one.   my only concern is which side of the suspension does the drop link go?  so looking from the back of the the car, does it go the wheel side or the other side?
Does it have the box section pieces?  They bolt to the shock and then the drop link bolts to that IIRC
No box section. Under where it bolts just wasn't sure which side of the shock they go?
Found this on the site. Hope it helps?
thats great so that shows its on the wheel side of the shock. i was gunna put in other side!
The 24mm one fits that side where as the 22mm one fits the other side with adapted blocks. Although the instructions I found for them say different
Bottom picture is what you need I believe?
yeah so fitted the arb today  only way i could see to fit which is weird and probably wrong, is to have one side inside the strut and one side out side it.  il attach some pics,   seemed to wide for inside the strut and to narrow for both outside the strut.
Definitely wrong.
Was it off a mk1 Octavia?
The drop links are supposed to be on the inside of the arb not the outside.
No it's off a Leon but uts the same floor plan no?
ok now sorted i think,! drop links now on inside looks much better, and more importantly feels awesome!
thanks simspj
Your welcome glad it's all sorted and handling great.
