Remote central locking
Just bought a 09 octavia but it only came with 2 non remote keys. I'm not sure if the car ever had a remote key but I would like one.
My 1st query is, is it possible to get a remote key, even if the car didn't come originally with one.
My 2nd query is, is it possible to get a remote key of the car originally came with one but it hit misplaced.
If your car is the the bog standard car it probably never had remote locking. Your CCM probably doesn't support it and will need upgrading. You can then buy two used remote fobs 2 has key blanks with cases (timpson will cut them) and swap over the immobiliser transponders from your current keys and electronics from the fobs. Some vcds coding will be needed and an aerial of some sort making to increase range. Will work as factory then, it's not a difficult job, all the info you need us on this forum but it's a bit of reading for you.
Edited by Nikonite
