Strut top mounts
Anyone know if kyb part number SM1713 are the correct top mount kits for my 06' vrs please?
Otherwise has anyone used the vetech top mounts or any others supplied by eurocarparts Jayar or gsf?
Edited by Chimpy12
I just bought Febi top mounts and bearings from ebay for about £42 delivered.
I was hoping to buy from one of the above company's so I can collect them tomorrow if poss.
Well I wouldn't worry then because every Fabia uses exactly the same top mounts and bearings, just grab what's in stock.
Brilliant, thanks.
  • Sponsor
Top mounts for a 2006 car with PR numbers G01 or G02 are VAG part number 6N0412331E
For PR numbers G03, G04 or G06 the VAG part number is 6Q0412331B
Don't know what the difference is.
Info from figs 41100, 41110 & 41120 here.
Look for one of those PR numbers on your boot sticker
Edited to correct first part number Q>N
Edited by Wino
Thanks for the info. Mine is G04. I have bought a pair of KYB sm1713 mount and bearing kits so hopefully they will fit.
Just check them in the shop, what I ordered as mounts were bearings at EuroCarParts
Haha yep the ECP website listings were so confusing I gave up and ordered through Jayparts. On the ECP site I couldn't work out which was the bearing and which was the mount or if they are supplied in pairs.
The only website I found with good clear info was AVS Carparts but I didn't order from them as I wanted to have them same day so couldn't buy online.
AVS supply Febi and Lemforder top mounts and they say both can be fitted to replace 6N0412331E and 6Q0412331B so I guess they are all the same.
Edited by Chimpy12
