Tow bar electrics
Anyone,
Does the 2004 Octy Mk1 estate have a plug on the wiring loom, to wire in a tow bar?
Jim
If you buy a dedicated kit from either skoda or westfalia, it will plug into you existing lamp plugs and have new plugs on the towbar loom to go onto the lamp units. You will also get a module to cover your indicators to enable them to work like the standard car would in bulb failure mode should a bulb blow on the trailer
just a note on this
when I gopt my plug in kit I bought a golf mk4 one as it was a fraction of the price for an octavia one and is physically identical
HOWEVER
the way the rear light plug on the wiring kit will need to be reconfigured as the golf rear lights are wired up to the same pins as the octavia ones
if you are electrically handy and have a meter this will be a simple job with a wiring loom pick -  it saved me over £80 at the time
Thank's for the input
Jim
