rear bumper removal
Appreciate this has been asked a few times, but struggling with a particular aspect
Anyone know how to remove the trim part under rear lights?
Appears there's a couple of bolts there
Thanks for any assistance !
Edited by Monkeyboyo
Does that help?
Thanks very much. A rescource I couldn't find earlier, but doesnt mention how to remove the part in question
Remove rear lights. 4 screws in each wheel arch and then 1 under each rear light. If you have reverse sensors light the towbar away from the car slightly and lower to the ground so you can disconnect the wiring loom.
If it's windy make sure you have some help as the bumper is quite flimsy and you don't want blown out of your hands.
Edited by CWARD
Thanks Wardy,
All removed, except under rear lights. This is inside vehicle right ?
When you take the rear lights out you will be able to see the screw from the outside.
