CCM Upgrade
Hi all,
I've gotta question for you all...
i have recently upgrade my BCM to the 6r7 937 087m version (PQ 25) to support Cruise Control and retrofitted CCS and got it working.
I now want to upgrade my key to a key fob with remote. Now my car came with central locking as standard (its a Skoda Fabia - TDI, type 2, 2011).
I've searched a lot and cannot figure out which part no. will be required to retrofit this too (i dont want to add any aftermarket system).
Now from what i've also read is that in the newer cars the BCM replaces the CCM and the BCM should support the upgrade. So assuming this is the case, all i need is a key fob, a skoda OEM transmitter and code it to the BCM using VCDS?
Anyone, know what needs to be done?
Sorry if i've posted this 2 times!
Cheers,
Aayush
2011 car the BCM and CCM are the same thing.
I have stack of them left over from cruise control retro fits, never actually needed to change one, even on a 1.2 three cylinder.
so then just the keys and I'm done - the BCM acts as a receiver and does the rest?
Cheers,
Aayush
Hi,
Does anyone know which fob key part no goes with this car or BCM?
