Cheap Alarm Module
Would you bother with the below?
My 2005 Octavia has a failed alarm module, with the below VCDS scan.
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
I assume the battery is dead as it's probably the original.
Second hand ones are available on eBay for around £20, but when will the battery fail in those?
This new one is available for £23.
http://www.aliexpress.com/item/VW-Car-Security-Alarm-Speaker-Horn-For-VW-Golf-mk6-Passat-B6-CC-Tiguan-Skoda-Superb/1184299636.html?spm=2114.01010208.3.2.NIQrqx&ws_ab_test=searchweb201556_1,searchweb201644_3_505_506_503_504_10020_502_10001_10002_10017_10005_10006_10021_10003_10004_10022_10018_10019,searchweb201560_3,searchweb1451318400_-1,searchweb1451318411_-1&btsid=2ea8fac0-80fe-4d60-9941-2e754da29532
Same part no as mine. I assume as it's a replacement, it will simply bolt in and plug in?
  • 4 weeks later...
Well I took the plunge and ordered this.
It tuned up in about 10 days. Not bad from China to the UK, tracked.
Exactly the same as the unit I took out. Even the same casing.
Fitted straight in and works no problem. I now have a working alarm :)
A saving of over £100 if buying a "genuine" new unit from Skoda.
Edited by softscoop
Thanks for the update might try it on my mk2 for 23 quid
Damn i ordered mines from ebay via china for around £40!
Well at least it was cheaper than the dealers
Edited by Awesam
