Fault code p0420
One of the Classic family fleet is a 2003 Fabia 1.2 with a 6 valve, AWY engine.
The engine management light came on about 6 weeks ago, with a fault code of P0420 " Catalyst system below threshold bank 1". The engine still ran normally but I found a split in the plastic brake servo vacuum pipe which was quite bad, and moving it caused the engine to misfire. I repaired the pipe, cleared the code and all seemed well until the other day when the light came on again. It has stored the same P0420 fault code. The engine runs fine but I wondered if anyone could shed any light on possible causes ? It has done 128k miles but has up to date service history. Cheers
Edited by classic
Short journeys I'm guessing, cat needs cooking up on a longer run to clear it out.
Thanks, but it does get a reasonable (40+ miles) round trip at least once a week. In fact the light came back on at 70mph around 80 miles into a 150 mile journey whilst on M62.
In which case it must be burning oil through the worn valve guides. Oil burning will foul the cat and put the CEL on.
That doesn't sound good ! I guess it's a reasonably high mileage for a small engine.
