Adding a rear wiper?
Hi! Does anyone know if it's possible to add rear wiper to a MkIi Hatch that hasn't got one?
I'm from China and I own a MkII vRS Hatch. Since there's only one trim level for my car, I couldn't get a rear wiper, so I've been thinking about adding one as it's quite useful. Apparently, apart from wiring, I'll need a new rear windscreen(better a tailgate?), a motor, a switch behind the wheel, and some parts for water spray system. Is there anything else?
Here's some pics of my car :)
With a MkIII Superb
Edited by NOSDylan
You'll need new glass but the tailgate might be OK. Other than that I think you've loosely mentioned most things, wiper motor, wiper, switch, some wiring and then a pump and tube for the washer fluid.
Couple of part diagrams that might help:
Tailgate - seems to only be one version, probably worth checking yours for a mounting point?
http://www.partsbase.org/skoda/octavia-oct-eu-2012-82710-rear-lid/
Rear glass - many versions
http://www.partsbase.org/skoda/octavia-oct-eu-2012-84500-window-glasses-seals/
Washer fluid pump
http://www.partsbase.org/skoda/octavia-oct-eu-2012-95510-windscreen-washer-system/
Rear wiper assembly - careful as it lists both sedan and combi parts
http://www.partsbase.org/skoda/octavia-oct-eu-2012-95530-wiper-and-washer-system-for-rear-window/
Slightly off topic, were those rear LED lights standard on your car?
I already have a pair fitted and coded in Mike ;)
I was hoping to get the original coding to see how close my guess work is! Depends what diagnostic tools NOSDylan has...
Washer fluid pump
Yeah they are standard on CN-Spec FL MkII cars. Here are two photos from the Internet.
VCDS, version 11.2 I guess? The real problem for now is that I can't get some of the parts I need :no:
That is a very old version of the VCDS software. The current version is 15.7.4
Not sure that software that old will even be useable on a FL?
Mike
Yeah it's usable. I was told my data cable only support this version so I couldn't upgrade unless I got a proper cable
