Rear Speakers, Help!
Hi.
Ive got a 98 lxi felicia and want to put some 6x9s in the back. Ive got the speakers but i have no idea where to wire them into the car. Ive looked at diagrams in the hand book but cant make head or tail of it.
Can anyone tell me where i would find the wiring to connect the speakers.
Thanks!
Just an update, i have found from the schematics that there are two 2 pin connecters for rear speakers somewhere in the car. They cant be in the back doors becasue no wiring feeds into them, any ideas?
I never found where they plug in but you can pick up the wiring to the rear speakers underneath the glovebox (lift the lid and remove the glovebox insert)and easliy run the leads under the trim and carpets to the rear. I did this on a 98 GLXi
I found the ends in the wires in the end. They are located in the two footwells at the front of the car. If you pull the carpet back from the plastic trim on the outside side of the footwells and rummage around behind there you should be able to find them, for anyone wanting to put rear speakers in.
