Superb II - LED DRL to be on permanent
Does anyone know where the LED DRLs can be coded to on permanently in the AUTO position on the light switch?
I went to a dealer last week for some servicing and they did mention they had to recode something.... and I might see some changes but they had not changed anything major. The service person was not too specific.
I did not notice the lights immediately but my DRLs are off in "off" and "Auto" whereas they used to be on in "Auto". They still come on with the Xenons automatically when it gets darker.
I could go back to the dealer but that might be more hassle.
What is the coding sequence on VCP to change them back to permanent?
Does anyone have an idea, where the LED DRLs can coded to be on permanently, i.e. in Auto, side and main lights?
Got an autoscan so we can see what's fitted in the car?
Also, have you checked the daytime running lights are enabled in the MFD/maxidot?
Do you have any old autoscan to compare with?
Otherwise, I'd start by looking at byte 15 bit 6 in the BCM (Address 09) :)
Thank you,
I activated #09(BCM) Byte 15, Bit 6 and Byte 26, Bit 3 which I also found out about in another forum.
