vRS needle sweep
Mine seems to always do it, but I hadn't even made that much of a fuss about the fact it does !
Was I doing the car a disservice?
They should do that as standard as its a test and it should do it every time the ignition is switch on, not when the lights are switched on, though you'll see if do it if the lights are on when the ignition is switched on.
it was one of the adaptation  options I enabled - ill disable it and see what happens
Does what, needle sweep or headlight dance?
Sorry, sweep.
:)   :thumbup:
