Ongoing issues
Around 3 weeks ago I did a 90 mile drive EML light came on and it presented a fuel map issue
On return we switched it off as car was running fine then we have a few glitches along the way!
1) side light bulbs burn out within 2 hours of replacing
2) P/S window won't go down
3) indicator won't click when turned on (not so much of a loss)
4) headlights will dim whenever I put the brakes on
And then the bloody EML light came back on last night aswell any ideas/advice?
Cheers in advance
Well resolving "1)" and "4)" needs to get done very soon - that should not be happening!
Sounds like the voltage regulator is playing up, I suggest you check the alternator output before the battery gets boiled dry.
Alternator is reading fine (hmmm) EML checked today and reads as a lambda sensor fault it's a weird one
