Air con fault code
Morning you lovely lot.
Done a scan on the car. Got the following code:00229 Refrigerant pressure below lower regulation limit threshold.
Take it the system just needs a regas or would the system have a small leak some where on the system?
You could try a regas but some of us, including me, have suffered damage to the air-con condenser at the front of the radiator causing a leak.
Cheers Leiger :)
