Need to reseal top of front windscreen because of rain water leak
is it possible to remove the top trim of windscreen,
because I´d like to reseal under it with some silicone and then add the trim again after resealing
I add a picture for you to see where I need to reseal
this is a skoda octavia ambiente 2003 hatchback
the trim is number 4 on this homepage picture:
http://workshop-manuals.com/skoda/octavia-mk1/body/body_work/glazing/window_mechanism/glued_windows/summary_of_components_of_windscreen/
anyone?
I'm not 100% but doesn't that trim require the windscreen off to take it off the glass. I think to fix it right the screen needs to be taken off and re-bonded, I just can't see a way of getting sealant in there past the trim without taking it off
Edited by SuperbTWM
I´m wondering If I could open up a small slit between the rubber trim and the red paint on the top.
I could use the end of a sealant tube to maybe put it in between and then it would maybe fix the leak?
Can pretty much guarantee that won't work. It's a windscreen off job.
Just do a windscreen claim on your insurance, it won't impact any no, won't cost much and will actually work unlike trying to pump some sealant in.
well I talked to a guy here in iceland who is working for a windscreen company and he told me to start to try add a PUR on the inside. He said they do It themselves.
I wen´t with the car there and they looked at it and saw that it had had a new windscreen fit on it maybe 6 years ago.  And the reason for the leaking is that the PUR is getting loose from the glass, so I bought some PUR from them and am going to try to add it from the inside.   I also got a cleaner and a primer with the PUR.   The guy told me to cut off the PUR where there is a leak and add the PUR there and also add PUR all the way across the screen.
Will I need to use this cleaner and primer product also or are they only added to the windscreen?
the products are:
dinitrol 520 and 530
and the PUR is dinitrol 501FC
