Any excel gurus?
Trying to find a neater way to do something.
I've a column which I want to pull the first 4 character from and then add to a string in another cell with a divider.
I've done it using   = LEFT(B5, 4) & "/" &
And repeating that for each cell in the column. It's just a bit clunky and I wondered if there was a clever way to do that for a cell range.
In terms of the formula that's fine and works for the one cell. I got the same result with the TRIM function: =LEFT(TRIM(A15),4)&"/"
To do a cell range I used the following formula looking at the data from column A1 to A10:
=LEFT(A1:A10,4)&"/"
 Do you have an example you could upload for us to help further?
Edited by Robshaw
I found a bit of VBA that does everything other than just taking the left 4 characters. -
Function ConcatenateRange(ByVal cell_range As Range, _
                    Optional ByVal seperator As String) As String
Dim cell As Range
Dim newString As String
Dim cellArray As Variant
Dim i As Long, j As Long
cellArray = cell_range.Value
For i = 1 To UBound(cellArray, 1)
    For j = 1 To UBound(cellArray, 2)
        If Len(cellArray(i, j)) <> 0 Then
            newString = newString & (seperator & cellArray(i, j))
        End If
    Next
Next
If Len(newString) <> 0 Then
    newString = Right$(newString, (Len(newString) - Len(seperator)))
End If
ConcatenateRange = newString
End Function
If I use  - =ConcatenateRange(B5:B17, CHAR(5))
it puts a pipe between the cells which is neat but I could do with cutting it down to the first 4 characters still.
VBA is a bit beyond me, I don't play with it very often.
But the original =LEFT(B5,4)&"/" does exactly what you want it to do, I wouldn't over complicate the situation by using VBA.
What else do you want it to do?
Nothing wrong with what you already have.
I assume you know about how to fill a formula down the column?
Just wanted a bit tidies so if I have to add any variables into the column they'd get included automatically into the range.
Plus I'm just being fussy and trying to have something a bit neater than that orrible clunky formula
In general, I use string slicing and ampersand("&") concatenation for this. I've never tried doing, say, {= LEFT(B5, 4) & "/" & $C$1/C5} though.
that bit of VBA works quite well but does anyone know how to edit it so it only selects the first 4 characters?
It's overcomplicating it to do a simple concatenation, but this only selects the first 4 characters
Dim cell As Range
            newString = newString & (seperator & Left(cellArray(i, j), 4))
        End If
    Next
Next
End If
End Function
Don't think it's that easy with the VBA as you can't embed the LEFT function in the formula.
So you'd have to embed in the VBA.
As softscoop has done above, and beat me to it!
