no boost and searching revs help plz
hi
have a 2004 mk 1 ovtavia vrs
around 2 weeks ago my revs started searching and had not boost and bit lumpy
after around 15mins it went back to normal
last night happened again
revs were on tick over around 2000
and no boost at all
tries it this morning
no boost but revs gone back to normal
also seems bit lumby
any ideas please
thanks
Edited by lee1972
Yes:-
  1. Get the fault codes read; they're only golden, not crystal.
  2. Write in English. For example, I've never heard of "searching revs" in a car engine before, and the closest thing I have heard of to it is not compatible with a loss of turbo boost.
sorry
rev counter going up and down
from 1000 to neally nothing then jumping to 2000 and down again
all over the place and not sitting at 1000 when on tick over
Possible coil pack failure. Any codes or eml light on.
Revs climbing up and down sounds airflow related to me. For example mine did it when a hose popped off my sai. But as Ken says that doesn't necessarily tie in with loss of boost. Definitely need a scan, some codes may not throw the EML on.
Edited by YellowCar
These engines are prone to having air leaks which can cause the revs to hunt at idle but probably not that much. As mentioned above i would check to see if there are any misfire codes logged.
Have a butchers around all the pipework anyway, an air leak could explain a lack of boost aswell
Edited by SuperbTWM
hi
thanks guys
the boost started working again last night all off a sudden why driving
but was still ticking over between 2000 and 25000 revs on tick over
there are no warning lights on
my friend is bringing the machine back from work tonight so will see what that says
thank you
A scan is always a good starting point. If there are codes showing up these could be old. Depends when it last had a scan.
Ok, that sound a bit like "hunting", which would mean over-fuelling on low (off-boost) throttle settings, so you see why I don't think that's compatible with a boost leak.
Or an issue with the idle stabilisation control, or the throttle position sensor, or even the engine temperature sensor...
I had a similar problem with mine a while back.
It could be worth just listening for an air leak. I wish I had started with that instead if the air filter/spark plugs/rocker cover gasket  :D
my leak was around the suction jet pump. My understanding (NOT A MECHANIC) was that it was involved with the Vacuum from the turbo?
Anyway theory right or not it worked for me. Good Luck.
