intermittent starting problem p0016 vrs tdi cr
just had timing belt done on 2.0tdi cr
car had never failed to start beforehand
now it statrs from cold every time but it can happen within a mile or 100 miles.once switched off it wont restart
tried wiggling keys,etc
give it ten mins and it fires
it might fire straight up
theres no reason behind it
fault code p0016 comes up
it then wont start if you clear it
once started the car will run as far as you want,knock it off and back on it might fire up or not
let it cool and it will fire up
been to a very good specialist who says it will be a timing issue
forgot to say
the cam sensor has been changed
the reason the specialist didnt do the job was he had too much on at the time
