Vcds will read engine but no other modules
As title, i have vcds lite and the vag kkl 409.1 cable, i am only able to read the enging module but says "no comunication from module" when i select any other modules.
Any ideas?
Im trying to activate a few options on my 2006 octavia vrs.
Any help and advice appreciated.
Thanks in advance
Sent from my SM-N9005 using Tapatalk
MkI or MkII, vcds lite only does OBDII on the MkII, due to the lack of CAN Bus.
Sent from my D5803 using Tapatalk
Its the mk2 octavia, it didnt work on my 2001 bora recently but it used to as i used it to activate cruise control.
You need full vcds to talk to can bus vehicles like the MkII.
I have VCDS and I'm not that far from you IIRC. I'd be happy to help.
As said, you need a CAN or MicroCan cable on a mk2 Octavia.
The older K-Line cables don't work.
Nice one, im not in any rush but good to know. I'll drop you a PM sometime.
Thanks again
