Weird Octavia behaviour!
Got back from work earlier on and locked the car up fine, literally have just let my dog out and put the recycling stuff in the bin at the end of my garden and I heard the cooling fans are permanently on constantly, just been for a short drive round the block got back locked up fine and two mins after locking it up, sure enough the cooling fans are back on.
I'm going to have to take the battery terminal off. Any advice or help Iv got the car booked in for an mot too tomorrow afternoon as well.
My car is a 1.6 CR TDI also :(
Mine did this when the coolant temp sensor failed
Ok thanks for that I will look into it tommorow after work :)
Is this located in the coolant reservoir?
No. IIRC it's on a coolant pipe where it comes out of the block.
I think the fan controller failing can also cause this.
Sent from my D5803 using Tapatalk
Thanks for that, my old Fabia VRS is proving to be more reliable than this bloody thing, firstly the EGR is goosed, then a hole in a coolant pipe, and now this fan issue!
This.
Very easy to do. Took around 5 mins start to finish. And about £4 from bay of E
Edited by Mikek3111
