Trailer hitch
I shall mount trailer hitch /tow bar on my Fabia 1.4 2000 model
Are there specific things I need to think about?
Can I use standard mounting kit?
How do I remove the rear bumper?
Edited by Torbo
Had mine off recen
Had mine off recently, dead easy, just a load of Torx screws. You have to remove the rear light clusters to get at some of them.
Edited by TMB
Thank you! I will try soon, when I get the tow bar in post.
Mounting of the trailer hitch /tow bar went good. But i will mount  reversing sensors in the rear bumper on my Fabia.
Can someone that have a Fabia with censors tell me the distance between the sensors?
I must drill holes for it....
If you carefully prise off the rubbing strip by starting at one end and working your way along you will see where the cut outs are in the rear bumper.
DB.
DB.
There in no holes. But du you mean that there is some mark where the holes shall be drilled?
I wish that some could measure the distance between the censors on a car that have censors originally.
