Drain holes.
Hi guys,
I read a post on here recently about drain holes,but could not find it to reply to it.Maybe somebody can help I keep reading about various drain holes being blocked how many drain holes are there around the bottom of the windscreen? I know by your posts that there are 2 in the scuttle (roughly what size are they) but what is puzzling me someone said there is 1 each side under the bonnet hinges is this right?
Many thanks.
john42
Yeah the scuttle drains are under the plastic panel in the bottom corners.
  • Sponsor
On 9N Polo they're as marked on these pics, in a bit and down a bit from what you can easily see.
Nearside:
Offside:
I imagine Mk1 Fabia is more or less identical.
You need to remove the arch liners to get at them properly,or take your wipers off and the scuttle panel.
On both the vrs's we own the drivers side was well blocked up with leaves and crap.Was causing windscreen demisting issues as there was a puddle permanently stood in the scuttle area.
Thank you all for your replies. Very good of you.
Wino thanks for the photos really informative.
John42.
