Water in footwell - wet around clutch footrest. where can it be from? Octavia mk1
Hi, I've hunted through the forums and investigated several things. I found and cleared a blocked sunroof drain and unblocked the drain under the front drivers wheel arch.  Everything appears to drain the right way and the damp on the front upright has gone. The back footwell has dried out after much effort. But the front footwell is still damp, especially around the footrest nearest the gearstick. I've not read about this so if someone can suggest where it might be getting in/travelling from????
Could be coolant leaking from the heater matrix, ( have you lost any coolant)?
have you had a windsreen fitted? I had a leak in the pssenger footwell, i solved , the trim below the windscreen wasnt fitted tight
are you sure its not just residual water from the previous leaks. The insulation under the carpet can hold a massive amount of water
