Erratic Idle
Dear All,would you please advise
When starting the engine the RPM gauge showing 1000 then after a while when temp gauge in the middle the RPM showing 750.till now every thing is OK.
The problem if I drive for a while like 30km then stopped at traffic the RPM goes crazy up and down from 1000 RPM to 250 very crazy then stalled.sometimes it never happen during the day!!!
The same Failure can be reproduced easily any time by turning on the A/C while engine Idle and temp gauge in the middle the RPM goes crazy and engine stalled.
My question is which part or parts to be (checked,cleaned or replaced?
I strongly suspect an air leak, either in the vacuum lines or at the manifold joint.
