Skoda superb reverse camera interface instalation
Hello
I need some help here if anyone can help me..
I bought from ebay a reverse cam interface for my rns 510 columbus..and i cant make it work..i mean the codin they told me to do ,its not working..i tripled checked the wires and everything is just fine.i checked the reverse camera ..i bought a clasic display and i plugged the rca wire into this display and it has signal when i pull it in to reverse.i did every thing..
This is the coding i tried:
In controler 10(park/steering assist) bit 0 -bit 5(rear view cam instaled) and also i disabled bit 4(optical ilustration active) because when i tried bouth it says:coding rejected.error31:request out of range
So i disabled optical view and i enabled rear view camera
After that in controler 37(navigation) bit 4 i enabled bit 6( back-up camera low)
I restarted the rns510 and still nothing apperas on the display.
Until this it was appearing the optical view.
CAN U HELP ME
The interface i bought is from ebay :RL-MFD3
This interface is special for aftermarket reverse camera
Maybe repost in Technical Zone and under Diagnostics and VCDS
Might get more help there
An autoscan would also help :-)
Are you getting a black picture when in reverse or is it like you've made no changes?
Edited by langers2k
Iangers2k
Exactly..like i made no changes..the only changes are:when i pull into reverse the the sound goes on mute and no optical view.since i made the coding i had optical view.but the screen remains the same.if im on radio remains there
When I added my RVC I did the following changes, I then had to restart the Columbus using the left/right/star method. Even without the camera connected I'd expect a black screen.
- 10: Park/Steer Assist -> Checked byte 0, bit 5
- 37: Navigation -> Checked byte3, bit 6
Can you post an autoscan showing how everything is currently configured?
Also, please don't start multiple identical thread, if you think your thread is in the wrong place then ask a mod to move it :)
Did you reset the columbus unit after the coding changes were made?
Yes i did.i reset it
langers2k
If the display was black?what was wrong?
Because today when i reversed appeard black screen.
If it's black, that suggests the headunit is trying to display the video/adapter from the camera but it's not getting any image to display.
The thing is appeard just once..i mean now it doesnt .
Could be a wiring problem?
