Intercooler maf sensor
Hi all,
How is everyone getting past the maf sensor on the cold side of the intercooler pipes, the kit iv got doesn't have the housing for it?
Thanks marko
Do you mean there is no port for a MAP sensor in your fmic kit for the pipe to throttle body?
Yes mate , I found a pipe with a port on ebay but whould rather remove is possible?
Doubt it mate, that pressure sensor is pretty important to say the least.
Bear in mind there are 2 different port sizes for the MAP and there's no real rhyme or reason to what was fitted on your car in factory, you will either need a small or large port, whip it out and measure it.
Sound mate Thanks, it's an 18mm iv got and getting a pipe made up with the map port :)
