Interpretation of the error code
I have a Skoda Fabia combo 2002. 1.4 petrol.
Has long had an intermittent windshield wiper problem. The wipers stop and so can not be activated in some ways. after a while they little.
Has been change wipermotor - wiper drag-and wiper contact, but the problem is still there.
Has been read out these errors:
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Control Module Part Number: 6Q1 937 049 C
Component and / or Version: 00 BN-SG. 1S32
Software Coding: 09226
Work Shop Code: WSC 13765
VCID: 3B75F111298209B44C4793
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
01599 - Main Relay for Electric Drive (J437)
07-00 - Signal too Low
Has anyone an idea of the above problem and an interpretation of the read errors.?
John
relay?
2 Faults Found:
John
http://wiki.ross-tech.com/wiki/index.php/01317
01317 - Instrument Cluster (J285): No Communications
Possible Causes
  • CAN-Databus Wiring/Connectors from/to Instrument Cluster (J285) faulty
  • Fault(s) stored in Instrument Cluster (J285)
Possible Solutions
  • Check CAN-Databus Wiring/Connectors from/to Instrument Cluster (J285)
  • Check Measuring Value Blocks (MVB)
    • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
I can find no reference to the others on Ross tech wiki.....
