wheel center caps removal
Hi
Dumb question time.
How do you remove the wheel center caps
thanks
Wheel off job and push them through from the back.
Cheers that will have to wait then. Ill health mainly heart problems stops that
When I took mine off to replace them for new ones I just screwed a screw into the cap and then pulled it off :)
No need to remove wheel
You could maybe try some strong adhesive tape or something similar and a swift pull (may need some cleaning afterwards to remove any adhesive residue).
Unless they are clogged with muck they should pop out easily.
Hadn't thought of that.  Simple yet effective.
Hi
Dumb question time.
thanks
If you are removing them to replace them with new one's just drill a small hole in the middle of each one then screw a self tapper in and pull the centre cap off with some pliers.
If you are removing them to put back on again then you will most likely need to remove the wheel.
