Front anti roll bar
If you undo the 2 bolts that clamp the bush to either side if the anti roll bar, can you rotate it?
I was goimg to say yeah, once its disconnectes from the drop liks, but i seem to recall the connection set up i different on the vrs to the diesels...
Yes, but you should be able to rotate it anyway.
Thanks both for your replys
