TDI DSG struggling in second gear on upward slope
We just recently swapped our 1.2 TSI DSG for a 170 TDI DSG.  Everything has been fine so far apart from one odd issue.  Coming up from my work underground car-park on a cold engine, the car starts up the ramp in D1, then rapidly changes to D2, whereupon it then almost comes to a halt.  Pressing the accelerator somewhat harder causes the car to change back to D1 and it then shoots away as would be expected with the 170.  I would have expected the TDI to pull quite strongly pretty much from tick-over, even in D2.  Has anyone else experienced anything similar, please?  Is there an impending gearbox or engine issue?  The problem is much less pronounced with a warm engine.
I never experienced this with either the TSI DSG or a previous VW Passat PD 170 DSG.
Seems like another example of reduced CO2 emission programming madness.
Obviously sports mode would hold first.
I find recalibrating the throttle pedal helps when these strange gearshifts occasionally happens.
If it's just that specific location your are not happy about use S instead of D until you are out on the road. Using S extends the time in each gear. Possibly a tight engine which will soon loosen up.
Fred
Edited by g6zru
I think what you will find is that it drives in 2nd gear but slips the clutch to smooth it out which makes it feel a little sluggish.
If you just keep a constant pressure on the throttle it will do just fine.
Thanks - how would I go about doing this, please?
Fred
Thanks, Fred.  Yes, I could do this, or flip it over to manual mode.  At the moment, I'm trying to figure out whether "they're all like it" or whether there is a developing problem with the gearbox.
I use this method:
With the ignition "off";
-Press the throttle pedal to the floor
-Turn on the ignition and hold the throttle down for about 20 seconds
-Turn the ignition back off and then lift off the throttle
