pollen filter
Hi,
Where would I find my pollen filter on a 2001 TDi estate? The air flow to the windscreen is poor to say the least - I am wondering if it is blocked. Although the garage I bought the car from about 10 months ago say they changed it.....
Cheers,
Matt
If its an octavia, then its located on the passenger side behind the "skuttle board" (thats the plastic bit that takes the run-off from the windscreen). You need to lift it up and it can be seen easily a few inches towards the inside of the car.
Do a search for installing a power cable into the car for an amplifier. It should reveal some pictures!
if you need to take the skuttle panel off you'll need to remove the wiper arms as well.
