Headlight conversion for european driving - Skoda Superb II
Thought I'd share the headlight conversion for European driving of my facelift 2014 Skoda Superb II S as I seen a couple of them with Eurolites attached.
I don't have the benefit of "Travel" or "Tourist" with the halogen headlights on my Superb  and last year I struggled finding how to convert them last year for driving in Europe - spending a lot of time with the master technician at my local Skoda dealership - apparently they are very different from the pre facelift models
I can now do it in a couple of minutes a side using an inspection camera and a small screwdriver. You need to remove the headlight bulb plastic cap, insert the inspection camera viewing the "wing side" rear of the reflector - follow up with a small but long screwdriver to move the lever (it clicks into position)
Hope this helps someone, I'd even bought a pack to Eurolites ready!
I've take photos of this years (today!) conversion:-
Edited by bigjohn
  • 9 years later...
Hi
I'll be travelling to France in September. I used to own a Saab, on which I could easily switch the headlights for European driving with a lever on each lamp. I now own a 2020 Superb iV, but I can find nothing in the handbook about this and, as I've often found, my Skoda dealer is useless. I saw your post from 9 years ago, but I can't figure out from your images what I'm supposed to do to change the direction of beam. Are you able to give any further instructions, please? I can't believe that I'm the only person with this issue.
Regards
Geoff
On 10/07/2025 at 13:26, BadHobbit said:
Hi
Then you're in the wrong forum section. This is the Superb II (2008 - 2015) section.
On 10/07/2025 at 12:26, BadHobbit said:
Hi
Your car probably has the latest LED headlight technology that may engage tourist mode when going abroad - detected using the satnav GPS. If it's the simpler LED I think the official VAG line seems to be no adjustment required.
[EDIT] I've found a previous link for exactly the same questions:-
https://www.briskoda.net/forums/topic/510655-adjust-full-led-headlights-for-driving-on-right/
To be honest I have the same issue with my new car (Swace) which has LED lights and no tourist mode and the lights do have a slight uptick to the left when you shine on a flat wall. It might need Eurolites stick ons - but looking at an example instruction sheet and manually making a temporary cover it doesn't mask off the slight uptick. There are multiple "bulbs" with LED headlights. I might leave alone and adjust to the lowest setting. Again my local dealer has no idea and it's not mentioned in the rather thick manual.
Edited by bigjohn
  • 4 months later...
anyone know if the xenon lights fitted to my 2014 Superb can easily be set to eu requirements without sticking eurolights on them as I need those for the classic I am towing over to belgium.
So it is about being used on Mainland / Continental Europe & left hand drive and not the UK part of Europe or Ireland / EU Right hand drive.
its a UK car ie RHD but given headlights seem to self adjust thought it might be easy to align them for an EU trip rather than stick eurollghts on.
Sorry Mainland europe - belgium/netherlands
