Bluetooth (1k0 035 730C) 9W2 how to works?
Hello
I have a skoda octavia II from 2007 (but I changed the canbus controller, and It has RCD 310 (swing) radio with MDI.. These works very well.
Now, I want to install a bluetooth modul. I prepared  the cables, it is works.  The VCDS  "see" the modul.. BUT I can't coding.
It has 2 fault..
My first question...
Can I use this without multi steering??
I see, some VW has some buttons of the roof. It can control the modul..
But I can't find the pinout :(
How can I use it without steering control.. ??
Coding...
412100? or 412120 ??
Or other??
Thanks..
Laci frong Hungary
Can you post an autoscan?
yes, in  this evening..
VCDS Version: Release 12.12.0
Data version: 20130910
Tuesday,17,May,2016,21:34:23:58797
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 77
VIN: TMBCX21Z172127470   Mileage: 112520km/69916miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 1010
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 AJ    HW: 03C 906 024 K
   Component:  MARELLI 4HV      G 0884
   Revision: --H06---    Serial number: SKZ7Z0G4047451
   Coding: 0004071
   Shop #: WSC 73430 790 00000
   VCID: 66C9DD6D5182602E0EF-8033
1 Fault Found
18106 - Please Check DTC Memory of Steering Wheel Electronics
            P1698 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 112431 km
                    Time Indication: 0
                    Date: 2000.01.01
                    Time: 07:11:13
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8728096E9811E6AD9-806A
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1Z0 820 047 D
   Component: Climatic PQ35   010 0301
   Shop #: WSC 00000 000 00000
   VCID: 346D772557DEC2BE40B-8061
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004709923
   Coding: 098C0F030004140000110D000000000000097F075C0000
   VCID: 6CDDAF454F6E5A7E58B-8039
   Subsystem 1 - Part No: 1Z1 955 119 C
   Component: Wischer 220207 022  0601
   Coding: 00055223
   Shop #: WSC 73430
1 Fault Found
00988 - Lamp for Brake Light; Right (M10)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 112175 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.35 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q2 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD122FRA
   Coding: 0020786
   VCID: 3D7B5201649403F6BF5-8068
   Subsystem 1 - Serial number: 6332MSME16364964A
   Subsystem 2 - Serial number: 6342MSME16363B45B
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000042
   Shop #: WSC 49037 233 45725
   VCID: 74EDB725175E82BE80B-8021
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 812 A    HW: 1Z0 920 812 A
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610056    Serial number: SKZ7Z0G4047451
   Coding: 0003101
   Shop #: WSC 80093 222 71269
   VCID: 3261713DADCACC8E527-8067
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 021210F2000319
   Coding: 350302
   Shop #: WSC 12345 123 12345
   VCID: 30657B3563C6FE9E243-8065
2 Faults Found
01303 - Telephone Transceiver (R36)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 20
                    Mileage: 109476 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:36:35
01044 - Control Module Incorrectly Coded
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 21
                    Reset counter: 255
                    Mileage: 109366 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:50:51
Address 25: Immobilizer        Labels: Redir Fail!
   Component: IMMO            VD1 1610
1 Fault Found
02241 - Engine Control Module; Immobilizer Data not Adapted
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 109868 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:37:41
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0090
   Revision: A1001003    Serial number: 7667499985
   Coding: 010000
   VCID: 26499D6D5102A02ECEF-8073
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0953
   Coding: 0000116
   VCID: 387543154BB626DE6C3-806D
1 Fault Found
00943 - Heated Exterior Mirror; Driver Side (Z4)
Address 44: Steering Assist        Labels: Redir Fail!
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.067 H07 1806
   Shop #: WSC 73430 000 90108
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Component:    KSG              0401
   Coding: 80D002007F2D8505084B010004CC
   VCID: 80056BF5D3E62E1E143-80D5
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000116
   VCID: 3973461170BC3FD693D-806C
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 M    HW: 1Z0 035 161 M
   Component: Radio-SWING   003 0003
   Revision: -----05S    Serial number: SKZ4Z2M1341151
   Coding: 050004000001
   Shop #: WSC 73430 790 00119
   VCID: 387543158BB626DE6C3-806D
2 Faults Found
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 100
                    Reset counter: 232
                    Mileage: 93068 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:30:59
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 254
                    Reset counter: 21
                    Mileage: 109476 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:36:34
Address 77: Telephone (J738)       Labels: None
   Part No SW: 1K8 035 730 C    HW: 1K8 035 730 C
   Component: Telefon       H08 6600
   Revision: 00008000    Serial number: 20389520190278
   Coding: 012120
   Shop #: WSC 05314 123 12345
   VCID: 29539651401C8F56E3D-807C
3 Faults Found
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 112521 km
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
01524 - Antenna for Telephone
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 112521 km
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
02791 - Telephone baseplate (R126)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 112521 km
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
nobody?? :(
Your VCDS is very old, you should update to the newest version: http://www.ross-tech.com/vcds/download/current.php
Then I'd suggest you clear all codes and post a new autoscan, mostly as there are a couple of intermittent ones that should disappear.
As for the lcode for 77, what does the tool tip suggest when you open the long coding helper?
I think you either need MFSW, buttons in overhead console or a touchscreen (RNS-510 or similar) to control it.
you will require a maxidot to work with the 1k8 module
