Skoda Fabia starting issues
Hey, I'm hoping you people can help me. Ive been having some trouble with my Skoda Fabia 1.9 SDI, W reg.
Some mornings you come to it and the light for the glow plugs doesn't come on and it won't start. Sometimes if you take the Kay out the ignition give it ten minutes it will come back on, Yet other times it won't, I've waited days for it come back on before now, I have also disconnected the battery and reconnected to see if it would do anything but doesn't change a thing.
I've also had problems with the car randomly cutting out whilst driving but suddenly starting again with a turn of the key.
I plugged the car into VAG.com I did a 01- engine module test and brought up the following fault codes
17656 P1248 35-00. I've be done a little bit of research and found it to be Injection start regulation control deviation, but all the reports I've read with this same error code reveals different symptoms to what I'm getting,
90% of the time she drives fine, this problem has been occurring a lot lately. Any help is greatly appreciated , thank You
Leigh
Upon further inspection, I've gone through other various modules. electronics 1, Instruments I get this following fault code
01314 Engine control module 49-10- no communications.
pretty much everyrhing else I'm getting no response from the controller
Anyone??
