Do FL LED estate tail lights fit the pre-fl?
Has anybody tried it?
Looking at the scan from my car, the BCM is 1K0 937 087 AB (car was built Dec 2011) which seems to have been fitted to cars with LED tail-lights from the factory. Does anyone know if the coding process for enabling LED tail-lights can be done in VCDS now?
Unlikely as it's all part of the byte 18 magic.
You'll need VAS-PC, ODIS-e or VCP to sort it properly as the correct lighting parameters cannot be set using just the lcode.
