Octavia 11 1.9tdi clutch rattle
Hi all, my 54 plate 170,000 miles car has delveloped a clutch rattle on tickover that disappears when the clutch is depressed.
We have owned this from new, full service history, motorway miles and on its third cambelt/water pump.
My question is does anyone think it worth going to the expense of a dmf full kit as the car is probably only worth £1000.
I hope this query is in the correct section and will supply more info as required.
P.s. looking for an octavia vrs now.
Great site, cheers paul.
if you are going to get another car i would just save your money and sell it or trade it in with a known clutch/flywheel rattle
you would be looking at around £750 minumum for a clutch and duel mass flywheel to be fitted
you can fit a single mass flywheel and clutch kit to the 1.9tdi i had it done on my old audi a4 it still cost me £500 and that was over 5 years ago
If it goes with just a gentle touch on the pedal, i.e. not releasing the clutch, then it may just be a noisy (dry) clutch release bearing.
Car could also go on for ages with a new Clutch and DMF or SMF conversion. Assuming it's ok mechanically otherwise.
I brought a Mk2 Elegance 1.9 184k on the clock rattle started 2 days later euro's is doing a deal this weekend I've got parts for DMF and clutch kit down to £310 5hr Labour for £200,all in around £550.
£300 for used gearbox with 3month warranty.
less than £50 an hour for labour thats sounds very cheap, most places where i live charge that for half an hours labour !
Most independents in my area charge around 40, I had a year box replaced on my 1.2 fabia for £120, shop about the polish indi wanted £200.
Sent from my LG-D722 using Tapatalk
