Battery relocation
I'm running a bit short on cash so I want to get all the smaller fiddly things done. The car is stripped, the back completely gutted, everyday 'comfort' doesn't bother me. It's how I want it. But with little weight in the back I'm consious that the car is now more front heavy and moving the battery to the back will help. I've got a rough idea but the thing that is bothering me most is the fuse box/tray thing on top of the battery, what have other people done with there's? Or is it a case of zip tie it somewhere (although not preferable).
Ford Galaxy/VW Sharan fuse box for the engine is what I have in mine. Far easier and very OE looking.
Few people have mounted it lower down where the battery was. Making a plate up would be quite tidy. Or relocate the fuse box with the battery.
This is the part number I got, Ford Galaxy which was used on the VW as well. 1112108
If you want something simple, but efficient, go with this stuff !
Thank you, I'll definitely look into that, where about did you mount it? I was thinking just behind the front N/S headlight there's a bit of free space
Does it need to be covered from moisture etc? Or is it alright open? If it's mounted on a plate under the bonnet that is
Edited by Oz9
Just above the gearbox. I'll post some pictures on my build sometime soon.
To bolt on or weld? Awesome, I'll check them out.
