Lowered with Passat hub's
Lowered today with apex 20mm springs new  genuine shocks and other bit's,Oh and er passat 3c hub carrier's.
New bearings fag
lemforder balljoints and droplinks.
GKN driveshaft's driver side on order.
Audi TT top mounts
Brake's next also some poly bushes in lower arm's hopefully
Over the moon with ride quality and lowering.
Before
Now
42095B90-43F8-406F-B844-BAB99266F559_zps
CE3429F6-2375-4BBC-8A32-D67FB8A7E911_zps
826A06E9-174B-4557-9F79-173D28E6C9EE_zps
16401A61-4993-4247-BDE8-3245DD7761F8_zps
87B8B122-DAF8-4664-9823-4D4BDF8B0030_zps
D9409473-A0E6-4903-9A14-DE5B6CBE7F3A_zps
4F357F4C-3656-4CDD-9DDE-6992A60516E8_zps
Edited by vrsRo55
Why Passat hubs? What's the difference?
Looking at the picture slightly wider track?
They could be wider i'm not sure.
But the passat hub carriers are alloy they are normally cast and very heavy.
What's the price difference then from standards to Passat
Not sure New,
But the cast new are £150-170 online.
Passat one's i picked up from a local Breaker's yard removed myself from a vandalized Passat. £40 :)
S3 lower arm's coming too.
With S3 caliper's i'd say i'd weigh what i did before.
Not sure New,
Why didn't you fit the Passat lower arms?
The Passat hub carrier is thicker where the brake carrier bolts on.  Did you have any issues with getting sufficient thread engagement?
Excellent mod.  Well done!
Haha yes i did quick trip to TPS for x4 longer bolts £20!!!
I didn't know at the time they would fit...
Maybe you can help then,what car has them and will fit the mk2
I'll guess Audi A3 Golf mk5/6/7? Jetta Passat
I'm guessing all the track rod end's are the same too?
Passat CC and the later models have the alloy lower arms.  Or the Audi S3.  As a long shot - possibly the Superb as well.
Tie rod ends attach to the hub carrier, not the LCA.  The console bush housing has slightly different bolt holes on the Passat.  You can re-drill them or retain the stock Octavia units.
Will i have changed the ET on wheel fitment?
It's all tracked now and handles A1.
Passat arms on order from breaker.with s3 bushes
I'm not sure what you are asking.
It looks like i have spacers fitted but i don't.
If i go for a wheel change.will i have to watch the ET and fitment ect.
Sorry poor explanation .
You will, but 5mm either side won't make any difference.  It depends where you want the wheel to sit in the wheel arch.
I know when I went from 6.5" ET52 to 8" ET35 it affected toe-out on turns but for most people they wouldn't have noticed the slightly off-puting behaviour when turning in.
If it's been aligned & feels good I wouldn't worry too much
Im thinking of a set of RS6 ronals 18s for winter.While i get my standard's painted. ET 42 or 45 8j will they be ok?
The wheels you have at the moment are 7.5" ET50 aren't they?
If you go to 8" ET45 that will be an extra 11mm poke outwards.  It should be OK providing you have sufficient guard clearance.
Shoot mee....Guard?
Shoot mee....Guard?
Sorry. Aussie-speak.  We shorten everything.
Mud guard = wheel arch
Made sense to me. Lol
LOL mud guards are optional extras.
No, that's a mud flap (flat rubber) or a mud spat (moulded)
Arh- we or i do at least call that an arch liner/shield.
Calling Brad Calling Brad lol
I have found a set of wheels. they are
 8J0601025AA
 9J 18 ET52
Any help would be excellent THANKS
Edited by vrsRo55
18" diameter x 9" wide ET52
I know the Audi TT 17x8.5" ET50 fit.  I have no idea about 9" ET52.  There are others in this Octy2 section that have been adventurous with wheels - they will know.  There have been a few threads on extreme wheel fitments.
What tyres would you be running?
ARH you just nailed it.225 40 18 with 9J that would be an issue?
225/40r18 will fit 7.5" to 9" rim width.  It will have that weird stretch look but is within manufacturers specs
