Recently i started noticing a clunking noise when i turn the wheel to right at some point
It keeps happening mostly wen its stationary
I got t checked with my mech he lifted the car up with me on it and tried to illustrate the same but no noise wen high above ground
He says its from steeringbox
Im kind of worried as this might end up as a very costly affair
Could this be a strut mount bearing tie rod end or steering ball joint issue? Or intermediate shaft ?
Do recommend what to do as he says power steerign syetm cannot be repaired as its sensors wil go bad and needs replacing have uploaded a video demonstarting the same
Kindly use headfones :)
Cant see it from steering box, more likely a track rod end or ball joint. No video there I can see by the way
Place your hand on each front spring in turn and get someone to go lock to lock if its a strut top mount/ bearing you should feel the twang on the spring
the sound isnt comtinuos its a tick and den goes and coems agai at that particular point
Would i feel the strut moving if i place it?
Possibly
