ross teck
can any body help fitted Columbus and module to 58 plate superb it needs to be coded i live in chesterfield s44 5tx Log-KP58OUD-49710km-30888mi.txt regards oldtimer
You clearly have VCDS as you've just run a scan. You can code it yourself, can't you?
not if he doesn't know which values to set :)
He's a better idea than me, as I don't know what options his car has. At least he knows that...
Hi to all yes i do have vcds having it dosen't mean i'm competent to use it yet still practicing with it that's why i'm asking for help,if its out there i've tried youtube some great vids but not when you carn't get your head round bitts bites I don't wont to bugger things up regards oldtimer
I took your initial post as asking for someone to come round and do it for you, given that you posted your post code. I thought it strange that you'd done a scan, and then asked for help.
So, you haven't done anything yet, other than the physical install?
I have just compared my VCP scans - 2014 model - with yours. Have you coded anything in your gateway STG19 and radio STG56?
No I wouldn't no where to start
Connect VCDS to the car, turn ignition on, open VCDS.
Press the "Select" button to open the control module list, and select "19 CAN Gateway". Then go to "Installation List" and you have a list of check boxes. Place a tick in the box for 37 Navigation and 77 Telephone. Then select "Save Coding" and close that controller
Then open "37 Navigation", select "Coding", then "Long coding helper" and choose the options and configuration for your car. It's just a matter of selecting the correct tick boxes for your configuration. Read the warning in red at the bottom of that section and it tells you to reboot the Columbus after changing the coding. Then exit Long Coding Helper and click "Do It" to save the configuration. Close Navigation controller, and reboot by pressing and holding the left and right arrow buttons (top left) and the "microphone" button (top right) until the unit turns off and reboots.
Scan for fault codes and clear threm as necessary. If any faults remain in the Navigation or Radio controller, then you've got something wrong.
thank you will give it a go when i finish work
Did what you have said but stopped at the first part 37and 77 we're already ticked
Then go onto the second part, and see what you can sort. Strange that the two controllers were already ticked. Maybe someone had them fitted previously, and removed them when they sold the car but failed to decode them. Have you cleared the fault codes?
If you are getting stuck & fancy a drive to bham ill code up for you.
OK i've tryed all that's been suggested no luck it keeps telling me basically module not coded so i'm at the mercy of any body local on the forum who can physically show me were i'me going or doing wrong oldtimer ps i don't exspect it to be free name your price ?
Take a look in the VCDS area of the forum, there's a list of VCDS members and also a map link.
Just been checking the Ross Tech wiki page for your fault code 01042 on the Navigation controller.
  • In certain cases this code may be stored even after properly coding a module (e.g. VW RNS510). In such cases make sure to use a proper workshop code (WSC), importer and device number. Those have to be non-0 values, so for example 12345-123-12345 should do it."
thank you i will give it a go     oldtimer
I know your there rustynuts dying to help pretty please        i've done as much as i can i've gone into the telephone part and its there that theirs no code any thoughts on this ? besides bugger of oldtimer
Okay, try this.
Go into the CAN Gateway list as I directed you above, and remove the check marks from the navigation controller 37 and telephone controller 77. Save the coding and exit.
Then run a full autoscan again and post up any fault codes you have.
ok will do just got to take son on a driving lesson oldtimer
Hi rustynuts,
As requested, did what you said. Below are the results hope this helps.
Saturday,04,June,2016,16:34:42:30882
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: TMBBF73T799016257 License Plate: KP580UD
Mileage: 49800km-30944mi Repair Order:
Chassis Type: 3T (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 62
72 77
VIN: TMBBF73T799016257 Mileage: 49800km-30944miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Not registered 0011
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BK HW: 03L 906 022 GA
Component: R4 2,0L EDC G000AG 2848
Revision: 13H01--- Serial number:
Coding: 0000078
Shop #: WSC 33361 790 00999
VCID: 6FED9F287EE5AE4697-803A
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 050 T HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1812
Revision: 04843012 Serial number: 00000808291160
Coding: 0000020
VCID: 2345A318E2AD5A2643-8076
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 3T0 907 379 A HW: 3T0 907 379 A
Component: ESP FRONT MK60 0102
Revision: 00H11001
Coding: 0006786
VCID: 3B757B787A1D02E66B-806E
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 N HW: 3T0 907 044 N
Component: Climatronic 122 0102
Revision: 00003001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_SK12.rod
VCID: 3D717560AC090CD655-8068
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 A HW: 1K0 937 087 A
Component: BCM PQ35 H+ 020 0358
Revision: 00020000
Coding: 40990AB8DC65F1C04008008111008FE403111BAE632085605C4040000000
VCID: 2F6D5F287E65EE46D7-807A
Subsystem 1 - Part No: 3T2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 26080 22 0602
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 220908 05 54 0402
Coding: 0730ED
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 165
Mileage: 49788 km
Time Indication: 0
Date: 2010.10.26
Time: 09:26:57
Freeze Frame:
Term 15 On
Voltage: 10.35 V
ON
ON
Term 50 On
ON
OFF
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0003
Revision: -------- Serial number: 66640824701186
Coding: 000104
VCID: 7EF3B26CE98FD7CE0C-802A
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 3T0 959 655 HW: 3T0 959 655
Component: J234__LAJ VW10 HI 1815
Revision: 17013000 Serial number: 003CCPJPKCA9
Coding: 0016714
VCID: 7EF3B26C298FD7CE0C-802A
Subsystem 1 - Serial number: 6333FTS613722528
Subsystem 2 - Serial number: 6343FTS614082528
Subsystem 3 - Serial number: 6353ETS66AESUVNP
Subsystem 4 - Serial number: 6363ETS6UQQJUVNH
Subsystem 5 - Serial number: 6373JTS6LJRGUVNH
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0001731
VCID: 76E3AA4C01BF9F8E54-8022
Subsystem 1 - Part No: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0011
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 3T2 920 940 D HW: 3T2 920 940 D
Component: KOMBI H28 0024
Coding: 410D00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 35616D409439D4969D-8060
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K089050295
Coding: EDA1FF060002023303
VCID: 35616D405C39D4969D-8060
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 126
Mileage: 49802 km
Time Indication: 0
Date: 2010.10.26
Time: 16:29:42
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H28 0024
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000003
VCID: 72EB965C6DD783AE78-8026
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 G HW: 3T0 035 680
Component: RNS-MID H50 5274
Revision: AB001001 Serial number: SKZ6Z7L8151055
Coding: 06000402040000A10000
VCID: 346750449743CD9EAA-8060
Subsystem 1 - Part No: 3T0 051 859 AL
Component: EU West V13 8348
2 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 126
Mileage: 49768 km
Time Indication: 0
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 24
Reset counter: 126
Mileage: 49768 km
Time Indication: 0
Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb
Part No SW: 7N0 959 793 A HW: 7N0 959 793 A
Component: TSG FA H03 0190
Revision: Serial number: 0000100274630
Coding: 011D0220DE01121002
VCID: 408F0C94D3FB613E3E-8014
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 196 2301
Revision: 00H15000
VCID: 2A5B4E3C85878B6E00-807E
Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb
Part No SW: 7N0 959 792 A HW: 7N0 959 792 A
Component: TSG BF H03 0190
Revision: Serial number: 0000100233966
VCID: 3F8D0F68AE051EC647-806A
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0133
Revision: 00H04000 Serial number:
Coding: 1377095
VCID: 346750445743CD9EAA-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l S004
Coding: 00000021
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r S004
Coding: 00000021
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 126
Mileage: 49768 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 25
Reset counter: 126
Mileage: 49768 km
Time Indication: 0
Address 62: Door, Rear Left (J388) Labels: 7N0-959-795.clb
Part No SW: 7N0 959 795 HW: 7N0 959 795
Component: TSG HL H02 0190
Revision: Serial number: 0000100272504
Coding: 010C00200001221002
VCID: 0109C9909871A83671-8054
Address 72: Door, Rear Right (J389) Labels: 7N0-959-794.clb
Part No SW: 7N0 959 794 HW: 7N0 959 795
Component: TSG HR H02 0190
Revision: Serial number: 0000100268426
VCID: 55A1CDC03C79F4967D-8000
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105234457
Coding: 020000000100000000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_SE36.rod
VCID: 2541BD002499A4162D-8070
3 Faults Found:
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 119
Mileage: 49689 km
Date: 2016.05.30
Time: 11:59:27
9458193 - Control Module for Cellular Telephone
B1052 14 [009] - Open or Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 119
Mileage: 49689 km
Date: 2016.05.30
Time: 11:59:27
13636352 - Control module not coded
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 119
Mileage: 49689 km
Date: 2016.05.30
Time: 11:59:27
End-------------------------(Elapsed Time: 03:23)--------------------------
Okay, now go back and reverse the procedure, retick the controllers 37 Navigation and 77 Telephone in the CAN gateway controller 19. Then save and exit.
Then go into Controller 37 Navigation and...
[read what I said earlier on about Workshop coding - In certain cases this code may be stored even after properly coding a module (e.g. VW RNS510). In such cases make sure to use a proper workshop code (WSC), importer and device number. Those have to be non-0 values, so for example 12345-123-12345 should do it."]
Select Coding. Now change the Workshop Code, Importer and Device numbers to 12345 - 123 - 12345, and then go into long coding and change something. I would suggest you untick the box for CD changer on the first page and nothing else for the moment, then exit Long Coding Helper. Check the Workshop code, Importer, and Device numbers are still what you set them at, and press "Do It" to change the long coding to the new number you've just generated in the Long Coding Helper. It should save the new coding and tell you it's done it correctly.
On your scan log which you've just posted (if you go and look in the Navigation controller) you'll see you have saved the coding with Workshop Code, Importer, and Device numbers as 00000 - 000 - 00000 which could be generating the fault codes.
Once you've saved the coding with the correct numerical codes for Workshop, Importer, and Device numbers, scan again and post a log.
Then you'll need to do something similar with controller 77 Telephone, but looking at the faults it would appear there's some wiring issues there.
did what you suggested i believe all went well with nav but phone no joy there was nothing to uncheckSunday,05,June,2016,15:04:58:30882
www.Ross-Tech.com
VIN: TMBBF73T799016257   License Plate: KP58OUDFOR
Mileage: 49840km-30969mi   Repair Order: forrustynuts part1
          72 77
VIN: TMBBF73T799016257   Mileage: 49840km-30969miles
37-Navigation -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
   Coding: 0000078
   Coding: 0000020
   Revision: 00H11001
   Coding: 0006786
   Revision: 00003001
   Coding: 0000000000
   Revision: 00020000
   Coding: 00D7B7
   Coding: 0730ED
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 165
                    Mileage: 49788 km
                    Time Indication: 0
                    Date: 2010.10.26
                    Time: 09:26:57
             Freeze Frame:
                        Term 15 On
                    Voltage: 10.35 V
                        ON
                        ON
                        Term 50 On
                        ON
                        OFF
   Coding: 000104
   Coding: 0016714
   Coding: 0001731
   Coding: 00000130
   Shop #: WSC 00000
   Coding: 410D00
   Coding: EDA1FF064006023303
1 Fault Found:
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 49802 km
                    Time Indication: 0
                    Date: 2010.10.26
                    Time: 16:29:42
   Coding: 0000003
   Coding: 04000402040000A10000
   Shop #: WSC 12345 123 12345
2 Faults Found:
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 67
                    Reset counter: 169
                    Mileage: 49768 km
                    Time Indication: 0
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 129
                    Mileage: 49849 km
                    Time Indication: 0
                    Date: 2010.10.27
                    Time: 14:58:07
   Revision: 00H15000
   Coding: 1377095
   Coding: 00000021
   Coding: 00000021
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 67
                    Reset counter: 169
                    Mileage: 49768 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 129
                    Mileage: 49849 km
                    Time Indication: 0
                    Date: 2010.10.27
                    Time: 14:58:07
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 49689 km
                    Date: 2016.05.30
                    Time: 11:59:27
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 49689 km
                    Date: 2016.05.30
                    Time: 11:59:27
          U1013 00 [009] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 49689 km
                    Date: 2016.05.30
                    Time: 11:59:27
End-------------------------(Elapsed Time: 03:18)--------------------------
I think you're gonna need someone on site to help here. If you unticked the CD changer option, why is it still selected and showing a fault code? You've made some progress insofar as you now have the Navigation controller partly (but still incorrectly) coded, and from here on it should be a simple tweak or two for your cars specific options. But it needs someone at the car to input the parameters for your options correctly. It really is as simple as "Have I got a CD changer?" - "No" so untick the box where it says "CD Changer" and then move onto the rest of the options and select as required. Next one would be "Microphone Diagnostics" looking at your  faults.
However, your telephone module appears to have some wiring faults which will need investigation. Can't do that over an internet connection I'm afraid.
thank you yes i agree i do need some one on site to put things right how ever you are the only one who as responded to my distress call ? perhaps some one dare i say as knowledgeable as you is close by i'm willing to travel not to far but to get this sorted will pay the going rate what ever that is ,its taking over my mind you bye a car an upgrade from my octavia and all i wanted to do is use my Iphone and it opened the biggest can of worms you couldn't ever imagine regards oldtimer
